Travis
First solution authored Welcome! 500 replies posted
The on-chip firmware resides in a non volatile memory namely the BootROM and is the first software of any kind to be executed by the CPU right after reset.
The on-chip firmware has two parts:
• Startup Software (SSW) which provisions the various boot modes and is the main thread of execution
• Test Firmware (Testware, not described in this document) which deals with test related routines that can be invoked by ATE in test mode only
Hi Travis,
Thanks for Useful Information, i need more information on What is Test Firmware? how can i find information Regarding This.
Thanks and Regards,
Harshan.
Travis
Test firmware is use by the factory for testing hence it is not required to be known by the user.
