06:31 PM
Nov 08, 2014
06:31 PM
Hello everyone!
My name is Remy and i am new in this Forum. I am using the XMC4500 and i have a big problem.
I wanted to programm a simple Timer which triggers an Interrupt (in one second two Interrupts) but it doesn't work and i don't know where the Problem is. (I'm not sure if the Timmer runs or the Interrupt is correctly configured)
Thank's for help!
Remy
#include
#include
#include "GPIO.h"
void CCU40_0_IRQHandler(void);
P1_1_set_mode(OUTPUT_PP_GP);
P1_1_set_driver_strength(STRONG);
P1_1_reset();
//------CCU4 initalization------
SCU_RESET->PRSET0 |= (1 << SCU_RESET_PRSET0_CCU40RS_Pos );
SCU_RESET->PRCLR0 |= (1 << SCU_RESET_PRCLR0_CCU40RS_Pos);
SCU_CLK-> CLKSET |= (1 << SCU_CLK_CLKSET_CCUCEN_Pos);
CCU40->GIDLC |= (1 << CCU4_GIDLC_SPRB_Pos);
CCU40->GIDLC |= (1 << CCU4_GIDLC_CS0I_Pos);
SCU_GENERAL->CCUCON |= (1 << SCU_GENERAL_CCUCON_GSC40_Pos); //CCUCON, that enables a synchronous timer start
//----------TIMER---------
CCU40_CC40->TCSET |=1;
CCU40_CC40->TC |= (1 << CCU4_CC4_TC_TCM_Pos);
//-------------Prescaler --------------
CCU40_CC40->PSC = 0b1010;
//------------Interrupt-----------------
CCU40_CC40->INTE |= (1 << CCU4_CC4_INTE_PME_Pos); //Interrupt Enable
NVIC_EnableIRQ(CCU40_0_IRQn); //Interrupt Enable
P1_1_toggle();
CCU40_CC40->TCCLR |= (1 << CCU4_CC4_TCCLR_TCC_Pos); //Timer Clear
cnt++;
Thank's for help!
Remy
07:59 PM
Nov 09, 2014
07:59 PM
Hi Renny,
Welcome to this forum. You might like to reference to the below thread link which shows an example of XMC1200 2sec delay example. Please follow the GUI configuration, signal connection and change the MCU to XMC4500.
http://www.infineonforums.com/threads/2335-Re-How-to-generate-2sec-delay-on-xmc1200
Best Regards
Travis
Best Regards
Travis
06:19 AM
Aug 07, 2015
06:19 AM
I just need to simply configure a timer and start counting. Please let me know the intialisations and start sequence. I am not able to find it out. No PWM and no other fancy stuff needed.
Sarath
Sarath
01:24 AM
Aug 10, 2015
01:24 AM
Hi Sarath,
The 'Software_Timers_Init()' function below may be all you need. Just call it in your 'main()' program, add the 'SYSTM001' App into your project and configure it's 'SysTick Interval' for 1mS.
In this example the constant TASK_TIMER_MS is set to 1 to call to my 'TaskScheduler()' function every 1mS. You can change this value to 500.
You can create your own function in place of my 'TaskScheduler()' function to toggle the pin.
Aaron
Aaron
// Setup SYSTICK based software timers using SYSTM001 APP functions.
// Inputs : None
// Outputs : None
// NOTES : SYSTM001_Init(); // This is called by DAVE_Init()
// Originator : Aaron Walsh 19 June 2013
void Software_Timers_Init()
handle_t TaskTimerId;
// Configure system timer to call 'TaskScheduler()' function every 1mS
TaskTimerId = SYSTM001_CreateTimer(TASK_TIMER_MS, SYSTM001_PERIODIC, &TaskScheduler, NULL);
if(TaskTimerId != 0)
//Timer created successfully so start it
SYSTM001_StartTimer(TaskTimerId);
