05:53 AM
Apr 05, 2016
05:53 AM
Hi
I'm trying to develop a socket server using xmc4500. Any example to start from?
thank you
thank you
Apr 07, 2016
06:51 PM
Apr 07, 2016
06:51 PM
01:54 AM
Oct 25, 2016
01:54 AM
ok thank you. Any idea to switch eth configuration from static to dhcp?
Nov 08, 2016
01:49 PM
Nov 08, 2016
01:49 PM
i have the same problem like ally, nobody knows that? Any examples?
Nov 15, 2016
12:42 AM
Nov 15, 2016
12:42 AM
In the above attached project, open the ETH_LWIP APP, in the IP Settings tab, click the "Use DHCP" check box. After this generate code.
04:03 AM
Nov 16, 2016
04:03 AM
Hey Jesus,
thanks for the answer, but this part is clear;)
Do you have any code examples for TCPIP Socket Ersver with DHCP or something like this?
Andi
Andi
Aug 17, 2020
01:49 AM
Aug 17, 2020
01:49 AM
I tried the example above on the XMC4500 Relax board, but i only can get it to run when I'm starting it from dave in a debug session.
Starting by just powering the controller using either usb port or after pressing the reset button does not work, i.e. controller is running (verified by toggeling a led) but I cannot connect over telnet.
Any ideas?
Any ideas?
Aug 17, 2020
02:48 AM
Aug 17, 2020
02:48 AM
ok, as i read somewhere else, upgrading the eth_lwip app to the most recent version fixed the problem.
(i was sure i had the most recent verions, but as it turned out all updates i did so far failed without notice presumably because of missing write access to the library store .... i wonder what other problems I encounterd are solved now aswell)
