XMC™ Forum Discussions
User18195
Hello everyone
Do you know if there are any tutorials how to properly use the XMC Library for Simulink?
e.g. configuring analogue inputs for PWM and stuff like that?
I know there are some examples in the Library but I don't understand how to set the right input ports.
(At least I can switch digital outputs on and off, but not controlled by inputs - only by time based simulink blocks)
I'm happy with every tips you can give me.
User19299
First solution authored
Hi Johannes,
I feel the same. There should be more examples and tutorials.
