04:23 AM
Oct 22, 2015
04:23 AM
I wannna transmit data through p3.2 with relax kit, but a high level remains after running on the corresponding pin. I ressigned p1.12 from p3.2, the high level still remains.
The code is posted as following:
DAVE_STATUS_t init_status;
CAN_NODE_STATUS_t mo_transmit_status;
CAN_NODE_STATUS_t status;
uint16_t counter = 0;
init_status = DAVE_Init(); /* Initialization of DAVE APPs */
if(init_status == DAVE_STATUS_SUCCESS)
else
while(1U)
/* Placeholder for user application code. The while loop below can be replaced with user application code. */
while(1U)
mo_transmit_status = CAN_NODE_MO_Transmit(&CAN_NODE_0_LMO_01_Config);
if(mo_transmit_status == CAN_NODE_STATUS_SUCCESS)
status = CAN_NODE_MO_GetStatus(&CAN_NODE_0_LMO_01_Config);
if(status & XMC_CAN_MO_STATUS_TX_PENDING)
XMC_CAN_MO_ResetStatus(CAN_NODE_0_LMO_01_Config.mo_ptr,XMC_CAN_MO_RESET_STATUS_TX_PENDING);
for(counter=0;counter<12000;counter++){}
else
while(1U)
while(1U)
