XMC™ Forum Discussions
I see the following map in the reference manual of xmc4500.
how many physical sectors are there? It seems that the logical UCBx Sectors are located in the physical Sector PS0.
I am using the normal boot mode.
Does that mean, if I use UCBx related command sequences, I would be unable to place my vector table at the very beginning of the PS0? Where can I then place my vector table?
1951.attach
Travis
First like received
There is a total of 6 physical sectors.
Nope, UCB is meant for flash memory protection.
User10696
Level 4
Level 4
First solution authored
I do not understand where the UCB Area ist. According to the documentation it is at 0x0C000000 + Offset 0x000000. This is then in Physical Sector 0.
What are the correct absolute addresses of the UCBs?
User8734
Level 4
Level 4
Read my posts about Flash Protection & Memtool.
BR
K
