Sep 11, 2015
01:33 AM
Sep 11, 2015
01:33 AM
I'm using the XMC4500-F144K1024 AB with DAVE4.
I have only the IIC-Master App and its dependancies in the project, and want to use the USIC2-Module, CH1.
According the xmc4500_reference_manual_v1.5_2014_07 on page 1815 you'll find USIC2_CH1.SCLKOUT is assignable to the Pins 3.6; 3.13 and 4.2. However when I select the Manual Pin Allocator in Dave I only get the option to select 3.6 or 4.2.
The same goes for the SDA-options: I only get P3.5 but should also be able to use 3.4; 4.0 and 3.12 if I check in the reference manual on page 1811.
Due to constraints in my design I need to use the Pins 3.12 and 3.13.
Is this possible?
Is there an error in the reference manuals or the dave app pin selector or do I just understand the reference manual wrong? please explain.
Andy
EDIT:
Reposted it to DAVE Forum, probably more relevant there:
http://www.infineonforums.com/threads/3308-XMC4500-DAV4-Problem-with-Pin-Assignment-USIC-Module-IIC-...
pls delete here.
Is this possible?
Andy
EDIT:
pls delete here.
Labels
01:56 AM
Sep 11, 2015
01:56 AM
I reposted it in the DAVE Forum
pls delete here.
pls delete here.
Sep 14, 2015
02:15 AM
Sep 14, 2015
02:15 AM
Hello Andy,
I will just close this thread since it has been replicated to the DAVE forum.
Min Wei
Min Wei
