Hi everyone,
I am using the an XMC4500 CCU4 / CC4 counter / timer slice for the Position Interface (POSIF) and I need to set the 'Compare Register' while the timer is running without having to wait for the Period to expire.
I need to set the 'Compare Register' regularly (for example every 1mS) and I can't risk losing encoder counts (position) while the CC4 counter / timer is stopped.
Is there a solution for this ? Maybe using an external signal ?
Thank you in advance for any suggestions.
Aaron
