Dec 06, 2015
07:06 PM
Dec 06, 2015
07:06 PM
Hi.
Now I have some problrms using CAN port of XMC4500(144-LQFP) and MDK-ARM 5
(port1 : P1.4, P1.5 port2 : P2.6, P2.7 port3 : P1.8, P1.9).
Transmitting to empty port(no node connected) ALERT bit of NSR register set(one)
and TEC value of NECNT register reach to 0x80.
Addtional transmission makes software upset.
How can I avoid software upset and how can I reset CAN port error without power off?
Please help me.
Best Regards.
Please help me.
Best Regards.
Dec 06, 2015
11:49 PM
Dec 06, 2015
11:49 PM
You can clear the error status flag and stop the transmission?
Dec 07, 2015
05:54 AM
Dec 07, 2015
05:54 AM
Hi. Travis.
Thank you for your response.
After connecting the nodes to the CAN port without turning off the power in the error state
I must continue to transmit data.
And the TEC value of NECNT is not clear even after the CCE of NCR is set
Is there no way to recover the CAN port error without turning off the power.
Best regards.
Best regards.
Dec 09, 2015
12:22 AM
Dec 09, 2015
12:22 AM
Hi. Travis.
After CCE bit set, error status can be cleared.
But data transmission is impossible through error happened port without power off/on.
This problem is critical to me.
If there is no way to resolve this issue I must redesign circuit and firmware with other microcontroller.
Please help me.
Best regards.
Please help me.
Best regards.
07:56 AM
Dec 11, 2015
07:56 AM
That is the normal behavior of a CAN node according to ISO11898
Because the behavior of the CAN controller is correct, it is your software what fails. You have to handle the Error Passive situation of the CAN controller without loosing control.
08:00 AM
Dec 11, 2015
08:00 AM
Every other micro controller will behave the same. Using another microcontroller or CAN controller will not solve your problem. You have to understand how the CAN controller is working. I have done many projects using Infineon CAN products and always was satified (at least at the end of the development).
Heinz
Dec 11, 2015
11:45 PM
Dec 11, 2015
11:45 PM
Hi. Heinz.
Thanks for your advices.
I understand that the set of error status bits and software failure due to continuous transmissions are normal behabior of CAN node.
What I want to know is how to recover the CAN port error without turning off the power of CAN port (control register setting or initialization etc. )
Best regards.
Best regards.
