User18523
Am using the XMC4500 relax kit. Now am trying to use CAN from the controller. My basic requirement is to receive some CAN frames from another module which throws data every 1sec.
I tried using the example program from XMC4500 libraries. The transmitter function works well. But am not able to use the receiver example.
Attached the receiver example which am using. The LED glows without receiving any data means nothing is connected in CAN but the LED starts lighting once the board is turned ON.
Requesting you to share some example code if you have.
