I have to connect the dog motor to the xmc4500 relax kit. Which pins do I connect them to and what is the syntax to tramit can messages ?
Thank you.
Hi @nagwekar ,
You can use the below CAN TX and Rx pins to connect the motor to the XMC 4500 Device.
You can find this in the XMC 4500 Datasheet
You can also refer to the XMC CAN application note for the Basic CAN examples which uses XMC Lib APIs.
Hi @nagwekar ,
Can you let us know which dog motor you are using and send us the specification of the motor.
Hi @Alakananda_BG ,
https://de.aliexpress.com/item/1005002019762665.html?gatewayAdapt=glo2deu
This is the motor in use.
https://docs.google.com/document/d/1dzNVzblz6mqB3eZVEMyi2MtSngALHdgpTaDJIW_BpS4/edit
This is the documentation for the same.
Hi @nagwekar ,
