Marcelo_Macedo1
10 replies posted 50 sign-ins 10 likes given
I'm helping a customer to implement Ethernet connectivity using the XMC4400, but I didn't find code examples to understand the memory (flash and ram) footprints. So, can you pls help me with below questions?
1 - Is there any SDK or code example to demonstrate the XMC4400 using Ethernet?
2 - We are using the board KIT_XMC4400_DC_V1 as start point to implement a FOC motor control along with Ethernet connectivity. So, I'm trying to calculate if the Ethernet stack can run along with the FOC code.
Marcelo Macedo - FAE at Neutronics
sujatapatil
50 solutions authored 10 likes received 100 sign-ins
Hi @Marcelo_Macedo1 ,
You can download example code( http_***) from below link,
https://www.infineon.com/cms/en/product/promopages/aim-mc/dave_downloads.html
The above example code will demonstrate usuage of LWIP stack ( Network stack) and it's configuration and how to establish tcp connection with http server.
you need at least  100KB flash memory to add ethernet connectivity to FOC example.
Sujata
sujatapatil
Sujata
