XMC™ Forum Discussions
mbenedikt
First like received First question asked Welcome!
XMC4300 Relax EtherCAT Kit
I can't find the Example Project XMC4300_Relax_EtherCat_APP_Slave_SSC.zip anywhere. The Links in the PDF-File of the description seams not to be uptodate.
onour
First like received 10 sign-ins 5 replies posted
Hello
I recommend you to dowload ModusToolbox,  from there you can go to File -> New -> ModusToolbox Application.
In this window, you can expand the "XMC BSPs" Kit and choose "KIT_XMC43_RELAX_ECAT_V1" and press next.
At this point, you will see all examples available for the XMC4300 Relax EtherCAT Kit, hopefully it help.
If not, you can look at this thread and find the solution (same example) you are looking for.
Best regards.
onour
Hello
Best regards.
