korneliuszo
I have problem with waking up from RTC event when I set HIB_IO_0 to high level.
Initialization of HIB_IO_0:
XMC_SCU_HIB_SetPinMode(XMC_SCU_HIB_IO_0, XMC_SCU_HIB_PIN_MODE_OUTPUT_PUSH_PULL_GPIO);
XMC_SCU_HIB_SetPinOutputLevel(XMC_SCU_HIB_IO_0,XMC_SCU_HIB_IO_OUTPUT_LEVEL_HIGH);
Setting up RTC event:
XMC_RTC_EnableHibernationWakeUp(XMC_RTC_WAKEUP_EVENT_ON_ALARM);
XMC_SCU_HIB_ClearEventStatus(XMC_SCU_HIB_EVENT_WAKEUP_ON_RTC);
XMC_SCU_HIB_EnableEvent(XMC_SCU_HIB_EVENT_WAKEUP_ON_RTC);
XMC_SCU_RESET_ClearDeviceResetReason();
XMC_SCU_HIB_ClearWakeupEventDetectionStatus();
XMC_SCU_HIB_EnterHibernateStateEx(XMC_SCU_HIB_HIBERNATE_MODE_INTERNAL);
Wakeup from hibernation works when I set HIB_IO_0 to low level
sujatapatil
10 likes received 100 sign-ins 25 solutions authored
Hi @korneliuszo ,
the hardware takes care to set this pin to low at the time of entering to hibernation and set it to high when leaving hibernation mode . No need to explicitly set it to Low , so please comment second line  in initialization above above and  check.
Sujata
sujatapatil
Can you check your external voltage regulator whether it is low enabled ?
Sujata
I use HIB_IO_0 to sustain battery power.
external voltage regulator is always on and I specially use XMC_SCU_HIB_HIBERNATE_MODE_INTERNAL.
sujatapatil
Hi @korneliuszo ,
Sujata
