Jedison
First like given First comment on blog 25 sign-ins
I would like to work with the XMC4200-F64K256 in an application, and would like to design the power supply to the MCU.
What is the maximum power to be supplied to this MCU?
I know VPPD = 3.3V but am not sure about the current needed.
Thank you in advance.
Jedison
Pradeep_PN
50 likes received 250 sign-ins 100 solutions authored
Hi @Jedison ,
Please refer to the data sheet of XMC 4200 .
Please refer to the sections 3.2.10 from the below document which says the worst case active supply current should be 140 mA.
Link : https://www.infineon.com/dgdl/Infineon-XMC4100_XMC4200_DS-DataSheet-v01_05-EN.pdf?fileId=5546d462696...
The typical and worst case consumption for XMC 4200 is 80mA and 140 mA.
Please refer to the below document power section (Page No : 45 ).
Link : https://www.infineon.com/dgdl/Infineon-IP_System_XMC4-TR-v01_02-EN.pdf?fileId=5546d4624ad04ef9014b07...
Hope this helps and let me know if you have any further queries.
Best Regards
Pradeep.
Pradeep_PN
Hi @Jedison ,
Best Regards
Pradeep.
Dear Pradeep_PN,
thank you very much for the reply.
It was excellent.
Jedison
