02:17 AM
May 01, 2014
02:17 AM
Hi, after installing and testing the device on Windows i try to get it working (vor development) on Linux
as a can see the debugger is from SEGGER
and after a short search
http://gnuarmeclipse.livius.net/blog/jlink-install/#GNULinux
i found the produkt *debugger* from SEGGER http://www.segger.com/jlink-software.html?step=1&file=JLinkLinuxDEB64_4.84.5
the problem is which serial number should i submit? where can i found the one from the windows version?
why is the linux software not in the download links below the xmc2go?
are there any hints to get the debugger running on linux *is DAVE running on linux?*
would be gread not to change the OS for Programming
01:39 AM
May 07, 2014
01:39 AM
Just connect your debugger into your windows and open the J-Link Commander.
You should able to see the serial number (S/N) of your emulator.
As for DAVE on Linux, I don't think DAVE is supported on Linux platform.
Mar 27, 2018
01:02 AM
Mar 27, 2018
01:02 AM
there is now a tutorial available how to develop code, debug and flash code to XMC controllers using eclipse on Linux:
https://github.com/furtnerthomas/Linux-XMC-Development
