William_Zion
5 replies posted 5 questions asked 10 sign-ins
Dear Support team,
     I want to kow how to use  XMC1402 UART DMA recive data? Would you please provide sample code for me?thanks!
Owen_Su
250 solutions authored 500 replies posted 50 likes received
Hi, @William_Zion
    I think this example meets your requirements: mtb-example-xmc-dma-m2m , if this not, you can find other examples in our Github: Infineon Github .
    I think that you can follow this example to add an interrupt to your codes, when received 8 bytes data(or other requirements), the program will enter the interrupt and transmit the data. Hope this can help you.
Owen_Su
Owen_Su
Hi, @William_Zion ,
    Here you can find the examples in Github: mtb-example-xmc-uart-dma
    This example demonstrates how to stream data using DMA via UART based on Universal Serial Interface Channel (USIC) to an external terminal. Hope this can help you.
Owen_Su
hi  Owen_Su,
     Thanks for your answer.  I have download this examples, but just  a UART TX  DMA example. Could you have   XMC1402 UART DMA recive data example?Thanks!
Owen_Su
Hi, @William_Zion ,
    Here is the link: mtb-example-xmc-dma . Hope this can help you.
Owen_Su
hi  Owen_Su,
      Thanks for your answer. This example is to use the 1ms time to fetch DMA data, so there will be a 1ms delay.I need realtime process recived data. For example: I set  the size of DMA buffer is 16Byte, when recived  8 byte data, it produce a interrupt event, then i can realtime process this data. How can i realize this funtion? thanks!
Owen_Su
Hi, @William_Zion
Owen_Su
