mh09
I am developing a board with XMC1400 micro. Can you explain how to output printf() to one of the serial uart ports? I looked at some examples but they all use Jlink connection and DAVE IDE console.
mh09
Owen_Su
250 solutions authored 500 replies posted 50 likes received
Hi, @mh09 ,
    Here is an  example which demonstrates how to use the printf function with a Universal Serial Interface Channel (USIC) based UART in XMC™ MCU devices. Infineon-mtb-example-xmc-uart-printf . Hope this can help you.
Owen_Su
Owen_Su
Hi, @mh09 ,
    Here you can find the example of XMC1400_UART, and it demonstrates the transmission of a periodic message via UART. https://www.infineon.com/cms/en/search.html#!term=UART&view=all
Owen_Su
mh09
Thanks for the reply. But I guess I did not explain about my problem well.  I want to use printf()/XMC_DEBUG() with the uart hardware. As far as I know all the solutions in the forum for use of printf() is tied to semihosting which outputs strings to a console of DAVE IDE via. jlink/XMC debugger. It is ok, but I also need another option to output strings by printf() to one of the uart hardware.
Thank you
Owen_Su
Hi, @mh09 ,
    Here is a code example using UART to output with printf() function: UART-to-output-with-printf-function , and it's also suitable for the XMC 1400.
    With ModusToolbox, you can find the example of UART_Printf . Hope this can help you.
Owen_Su
Owen_Su
Hi, @mh09 ,
Owen_Su
