XMC™ Forum Discussions
User14451
10 replies posted 10 questions asked 5 replies posted
Hallo All,
some of you have ever tried to make a project with DAVE 4.4.2 for a XMC1302 in T028 version?
I found that THERE IS ONLY DEFINED THE 16Kb FLASH VERSION, despite of in the wizard you can select all the FLASH sizes: 16,32, 64, 128 and 200Kb.
Do I have to modify the xmc_device.h adding the #define lines?
To be honest I would prefer to have some precious suggestions from Infineon XMC expert..maybe I have to add lines also in the other XMC Lib.
Thank you for your reply.
Best Regards
Ciao
Fabio
jferreira
First like received 750 replies posted 500 replies posted
Hi Fabio,
This issue should have been fixed long time ago.
Which version of XMCLib are you using in your DAVE4.4.2 installation?
You can check in your project the file xmc_common.h.
You can also try by upgrading to the latest device pack, in DAVE4 click on Help>Install DAVE APP/Example/Device Library... In the dialog select under Work with, select DAVE APPs Library Manager.
4562.attach
User14451
Hello Jesus,
now works!
Maybe I have missed some updates....
Thank you very much for your precious help, as usual 🙂
Best Regards
