ASAZHANG
I use XMC1302 control motor(FOC), the motor phase current  contain negative. Normal set offset valtage by OPA, I have seen some  XMC references to save the OPA, and use VADC Gain, how to measure negative current.
Asa
LinglingG_46
1000 replies posted 10 questions asked 5 questions asked
Why do you find the  references to save the OPA?
I see the kit use the OPA from below linker:
https://www.infineon.com/cms/en/product/evaluation-boards/kit_xmc1x_ak_motor_001/
LinglingG_46
ASAZHANG
Hi Lingling,
感谢帮忙。
电机的电流有正有负,如果采样负电压的需要用运放加个偏置电压,转成正电压使用。看到XMC1300中ADC带有增益放大,那负电压怎样采集呢?我看到Infineon的好多电机demo上是加了外置运放的。
Asa
