Mar 03, 2016
04:48 PM
Mar 03, 2016
04:48 PM
Hi~
There are questions about the CCU8 Trap.
Configuration are as follows:
- edge aligned
- asymmetric
- CCU8 event0 - start
- CCU8 event2 - Trap
- Compare2 match while counting up
- event2
The PWM waveform is output when the external pin to start CCU8 and Compare2 match while counting up
event occurs and interrupt
At this time,
If a different external pin to give a signal to the trap event2 pwm output does not go.
But compare2 event interrupt and is still occur
Are there any other event that can not operate when the trap work?
- edge aligned
- asymmetric
- event2
At this time,
