05:27 AM
Jul 15, 2014
05:27 AM
I'm going to get an ISR every 300ms. I have some problems if I would use "SysTick_Config(SystemCoreClock / 3);"
because some of my LEDTS function doesn't work right.
Isn't there any other timer like the ATmega8 has?
Bernd
Bernd
01:21 AM
Jul 16, 2014
01:21 AM
Hi, BerndB,
You could use a hardware timer.
Use PWMSP001 App and remove the pwm-output-pin -> what you get is a hardware timer.
All the best,
Wilhelm
All the best,
Wilhelm
01:25 AM
Jul 16, 2014
01:25 AM
Thank you Wilhelm,
Is it possible to include a App in Keil IDE?
Bernd
Bernd
Jul 17, 2014
01:13 AM
Jul 17, 2014
01:13 AM
Hi, Bernd,
Using Infineon's DAVE and KEIL-tools together will give you an easy-to-use development flow (see http://www.keil.com/appnotes/files/apnt_258.pdf, page 2).
It combines DAVE’s powerful configuration tools and Apps library with μVision’s project management, debug capabilities, and the ARM C/C++ compiler.
All the best,
Wilhelm
All the best,
Wilhelm
