XMC1000 device only consist of ONE flash module.
Any flash erase or write operation will stalled the CPU as no data can be read during this period.
The minimum size for flash erase is one PAGE size which is 256Bytes.
The minimum size for write to flash is one BLOCK size which is 16Bytes.
The erase cycles of the flash can be up to 50,000 cycles with 10 years data retention.
Flash driver for read, write and erase is provided as DAVE App in DAVE3.1.8.
For more information regarding the flash parameters, please refers to the device datasheet.
XMC1000 Webpage
