Hello
Question :-
The Evaluation board EVAL_3K3W_LLC_HB_CFD7 is a DC to DC Converter.
ispn:24821:1:0
ispn:8565:1:0
l1:314:1:0
XMC
Hi Ashwani,
As told in the kit user guide, "The controller includes serial communication interface (UART) and a propietary protocol allowing the parametrization of the HV MOSFET dead-times, output voltage settings, protection activation/deactivation and monitoring of status.
The user interface for Windows OS is an example of the capabilities of the communication library
included within the controller firmware. The user interface was specially developed to communicate with the
controller through the XMC™ Link (converts UART to USB), although other serial communication interfaces are
also possible."
As other interfaces are possible you can use this to transfer the UART data through any wireless interface. But the protocol in proprietary and you need the GUI to parameterize the values. So at the target computer you can have this GUI again installed to see the values.
Vasanth
Hi Ashwani,
also possible."
Vasanth
Thank you vasanth for your response
Can you guide me the steps to transfer the UART data through wireless interface.
Ashwani
Hi Ashwani,
Kindly check the wireless portfolio and decide upon decide exact module you are going to use. Check the the device documentation and examples available. Also make use of the community .
Vasanth
