Hello Sampath,
Could you please suggest suitable XMC Series Controller Eval Board for controlling 48VDC BLDC Motor for E-Vehicles application. We have Card for Driver and MOSFET side. We just need Controller and reference FW to control BLDC Motor. Please response ASAP.
Hi @PranayU,
Please refer to the document: XMC™ in motor control applications for choosing the control card based on your application need.
XMC1300 controller can be used for 48V BLDC motor control.
For reference firmware please refer to PMSM_FOC_EXAMPLE_XMC13: https://www.infineon.com/cms/en/product/promopages/aim-mc/dave_downloads.html
Please refer to the app note: AP32370 PMSM FOC motor control software using XMC™ for more details of firmware.
Krupashankar
Hi @PranayU,
Krupashankar
Is this PMSM Example suitable for BLDC ?
Hi @PranayU,
Yes, BLDC motors are S-PMSM motors mostly. FOC code can be used to control BLDC motors.
Could you please share what is the sensor which is being used to measure the angle?
Krupashankar
We are using 3 Hall Sensor and 6 commutation stage.
Power Electronics Driver part is working, and we have issue with code as we developed code for Psoc-1 device and now we stucked in compilation issue.
So now we need on uC Eval board so that I can integrate controller section to our Power electronics design and test.
Yes, XMC supports the hall sensor.
Please suggest, suitable Eval Board for XMC1300 for BLDC testing so that we can test with our Power Circuit.
Hi @PranayU,
We would recommend XMC1300 Motor control Eval kit - KIT_XMC13_BOOT_001
Krupashankar
