XMC_SCU_CLRSTSTAT There may be a problem with this function
Jun_ZW
First reply posted First question asked First like given
The XMC_SCU_CLRSTSTAT function in the xmc4_scu.c file in XMCLib.
  • void XMC_SCU_CLRSTSTAT(void){
    uint32_t u32clregtemp=SCU_RESET->RSTCLR;
    SCU_RESET->RSTCLR=u32clregtemp&0xfffffffe;
Why is the last bit not cleared?
I think it should be like this:
    SCU_RESET->RSTCLR=SCU_RESET->RSTCLR|0x01;
Vasanth
No Problem Jun. Thanks for confirming that the issue is not with XMCLib.  Following are the status register bits and status information. You can modify the custom API according to your requirement.
Vasanth
Vasanth
Can you confirm the XMClib version you are using at your end ? Is it  XMClib v2.1.24 ?
Vasanth
Jun_ZW
I got it wrong. This function is provided by FAE.😅
Vasanth
Vasanth
