Javier_ITA
5 sign-ins First like given First question asked
I have several debuggers (XMC Link) connected to the same computer. From the XMC Flasher GUI (i.e. the Windows app) I can select which debugger I'm using (Configurations/Change/Select Emulator...), but there is no argument option from the command line, at least not in the list of arguments shown with the -help option. So, is there any way of selecting the debugger from the command line without using the GUI?
Javier
Vasanth
Hi Javier,
In Jlink commander is running in background to make it possible. In Jlink commander you can use the following commands.
ShowEmuList : Shows a list of all emulators which are connected to the host. The interfaces to search on, can be specified.
selemu : Select a emulator to communicate with, from a list of all emulators which are connected to the host. The interfaces to search on, can be specified
Vasanth
Vasanth
Hi Javier,
Vasanth
