When I open the XMC Flasher software, A Java has occurred prompt pops up. My computer system is win10, and the JAVA version is 12.0.2. How can I solve this problem?
Thanks!
Hi, @SunQihao ,
Have you installed the Java Runtime Environment prior to XMC Flasher? Here I provide you the package or you can download it from the official website. By the way, you can refer to this thread which met the same problem with you: https://community.infineon.com/t5/XMC/XMC-Flasher-Java-Exception/m-p/362936
Hope this can help you.
Owen_Su
Hi, @SunQihao ,
Owen_Su
The thread will be closed due to long time no reply, you can create a new one if you have another question. Thanks for your understanding.
Owen_Su
