XMC™ Forum Discussions
CHubbard
First like received First solution authored First reply posted
I have downloaded all required software for the XMC Flasher (Java JRE 18.0.2) as well as Segger JLink but when I attempt to run the XMC Flasher from both the developer center, as well as the file installation location I am receiving a Java Exception. I have attempted to run this from windows powershell as well and I also receive an  error of: Exception in thread "main" java.lang.NoClassDefFoundError: javafx/application/Application.
I'm not exactly sure what to do at this point, so any help will be appreciated.
CHubbard
Yes I did have Java installed on the system, I did figure out how to fix the problem though. Even though I was using the most up to date JRE, I uninstalled it and installed the minimum required version of Java which it states as JRE 1.8.0_72. After that everything started to work just fine. So just a note to anyone who may see this problem, downgrade your Java and that could potentially work.
ncbs
Moderator 50 likes received 250 sign-ins 250 replies posted
Hi @CHubbard ,
Do you have Java installed in your system? If not, can you try installing Java Runtime Environment prior to XMC Flasher?
Nikhil
CHubbard
ncbs
Hi @CHubbard ,
Glad your query is resolved.
Please feel free to post any queries or issues you may have on Infineon products here and the community will be happy to help.
Nikhil
