User16575
Micro controller: XMC 4200 F64x254
Issue: When Setting PC2 of P2_IOCR0 to General-purpose output ( 0b10000 ), my firmware crashes and the debugger disconnects.
Even setting the register directly in memory (0x 4802 8110 to 0x 80 0000 ) cause the firmware to crash(debugger disconnects and firmware seems to stop executing without entering an event handler).
Has anyone come across this issue before?
Russell P
EDIT: The register is P1_IOCR0, not P2_IOCR0 . (Port 1 pin 2)
jferreira
5 sign-ins First like received 750 replies posted
Do you have connected P2.2 to some external component?
User16575
Its connected to the enable pin of a 3.3 Volt IC. We were able to circumvent the issue by connecting a different pin on the XMC 4200 to the enable pin of the IC.
Russell P
User16575
Any update on this ?
jferreira
There is no problem setting the P1_2 to output mode.
3677.attach
User16575
Ran your code, and now things are functioning, which puts me at a loss for whats wrong. Ill continue to investigate. Thanks for your help.
