Apr 22, 2020
04:54 AM
Apr 22, 2020
04:54 AM
Hello
I need to program an XMC1203 (on my custom board) using XMC1300 boot kit
XMC1203 custom is connected via P0.14 and P0.15 pins to boot kit ;
Jlink can not connect to XMC1203 custom.
Someone says that the problem is because BMI is set to ASC_BSL as factory default setting
How can I connect to XMC1203 custom using jlink alone ?
Why Jlink from boot kit can not connect to my MCU but can connect to the mcu from boot kit ?
Apr 24, 2020
02:42 AM
Apr 24, 2020
02:42 AM
Hi fionut.
Did to update the segger jlink software to the actual version? Perhaps you use a old version of jlink software with this bug.
After update and reconnect your boot kit, a firmware update was made to the board.
A normal JLink can handle the ASC_BSL mode and switch it to the SWD-Mode after new power on of the board.
The boot kit should do the same.
Apr 27, 2020
04:56 AM
Apr 27, 2020
04:56 AM
Jlink Config says my board does not need an update, it has the latest firmware
Apr 30, 2020
03:09 AM
Apr 30, 2020
03:09 AM
Please use SEGGER JLink commander get_bmi, set_bmi commands
07:21 AM
Apr 30, 2020
07:21 AM
JLINK CAN NOT CONNECT TO MCU
SO I CAN NOT SEND ANY COMMAND
What works is to change BMI from DAVE 3 .
Also XMC Flasher does not connects allways. When it can not connect to MCU , if I read bmi from DAVE, XMC flasher can connect!
May 06, 2020
12:46 AM
May 06, 2020
12:46 AM
I have managed to do it automatically in the end, with a combination between XMCFlasher.jar (is jar file, so can be called using command line) and Jlink.exe
