Hi guys,
Hello Guys,
I am beginning to start FlashBootloader implementation. I need to integrate your Flash Library to erase sectors and program them. I am using the XMC 4500 . I cannot use the CAN BSL mode as I need the boot to be always present.. I have a few questions:
1) Do you have an Application Note for boots which will reside on code flash?
2) As far as I know you cannot execute code from flash and program/erase flash at the same time. Do you have any sample code which shows how to handle code flash operations executing code from flash
3) I would need to know how we can execute code out of RAM to solve the above problem. If you have any other solution do let us know. Sample code would help.
4) Is there any updations in the flash library? Can you send me the latest one?
Sarath
