Aug 17, 2022
07:27 PM
Aug 17, 2022
07:27 PM
3 phase motor 2ea FOC control
- Difference in gate control signal method
MCU: XMC4400
a . Use 12 DAVE app 'PWM_CCU8' → CCU8 *12
b . Use 2 DAVE app 'PWM_SVM' → CCU8 *12 + Enable, Trap
When developing motor control SW,
1. please explain the difference in control method when designing 'PWM_CCU8' and 'PWM_SVM' in DAVE app.
2. If you have a 2 motor FOC control example, please share.
Labels
XMC
- foc
09:21 PM
Aug 17, 2022
09:21 PM
Hello @Donald ,
- PWM_CCU8 is the PWM generation APP using one timer slice of CCU8, with external events and dead time support, to generate up to 4 PWM outputs. For this externally the PWM generation scheme needs to be set. The options can be seen in the app GUI.
- PWM_SVM APP generates space vector pulse width modulated outputs to drive three phase two level voltage inverter. The APP uses CCU8 peripheral for generating PWM and uses low level driver APIs for configuring peripherals.
- Please refer to this thread : One XMC controls two pmsm to get some insights.
Sai
Sai
09:21 PM
Aug 17, 2022
09:21 PM
Hello @Donald ,
Sai
Sai
