06:40 AM
Oct 16, 2015
06:40 AM
I am using XMC 4100 for transmission of CAN Frames,I have configured MO 0 (for NODE0) as A Tx message Object. The Transmit Request Bit(24th bit) of MOCTR is getting Set automatically and then transmitting 17 CAN Frames in single instance, mean while TEC count increases and NODE is going into BUS OF STATE !!
05:58 PM
Oct 20, 2015
05:58 PM
I can't follow you. But a high level remains on the TX pin when transmitting the LMO data, I really dont't know why. Your data is transmitted successfully, is that correct?
02:28 AM
Oct 23, 2015
02:28 AM
Yup it's transmitting successfully, But the problem is in a single instance it is transmitting 17 frames moreover after transmission the TXRQ bit is not getting reset ,automatically it is set always.
