05:00 AM
Dec 16, 2015
05:00 AM
Hello together,
I try to run a example created for Dave3 in Dave4.
I arranged the settings, so that I can compile the Project with Dave4,
but when I start the debugger, the Programm gets stuck in the startup.s file at Default Handler: b.
Any idea, what could be the reason for this?
The Example I use is XMC4500HB_HTTP_ROM. You can find it on the webpage
http://www.infineonforums.com/threads/1828-XMC_HOT-XMC4500-How-to-create-a-CGI-and-SSI-web-server-wi...
Is there a similar example with CGI and SSI for Dave4?
Thanks!!
Thanks!!
11:45 PM
Dec 16, 2015
11:45 PM
Hello together,
the text of my Thread disappired, so here is a similar text, what it is about:
I try to run a example XMC4500HB_HTTP_ROM created for Dave3 in Dave4.
The Example I found at http://www.infineonforums.com/threads/1828-XMC_HOT-XMC4500-How-to-create-a-CGI-and-SSI-web-server-wi...
I imported it with "import existing projects into workspache" and arranged the settings, so that I can compile the Project with Dave4,
Dec 23, 2015
12:16 AM
Dec 23, 2015
12:16 AM
Hi Madde,
So sorry that you are stuck with the only HTTP CGI and SSI example for DAVE3. Currently I only have a simple HTTP using socket connection with RTOS example for DAVE4 (xmc4500_relaxkit_lwip_httpserver_netconn.zip). Please give this example a try first.
Next you can then port in the necessary CGI, SSI and HTTP application from this project "XMC45_HTTP_WebServer.zip" which runs on DAVE3.
Best Regards
Travis
Best Regards
Travis
