01:49 AM
Jun 06, 2016
01:49 AM
I am eager to learn what's the difference between app PWM_CCU4/ PWM??
I am going to implement an adjustable PWM duty cycle output which could cost the minimize .hex code size. Thanks for any advise in advance!
regards,
Fender
regards,
Fender
06:09 AM
Jun 22, 2016
06:09 AM
Hi Fender,
The PWM app has fewer features available than the PWM_CCU4 app. If you add both of these apps to your project, and then look at the configuration options, you will see many more choices in the PWM_CCU4 app. You can also go through the help for each app to check out all the related configuration description and methods available. The usage section of the app help shows an example of how to configure the particular app.
Best,
Rick
Best,
Rick
