XMC™ Forum Discussions
Dear,
There is a problem confused me, that what's output in CCU40.OUT1 in Capture Mode.
I know how to generate a PWM wave in Compare Mode, while Capture Mode is different.
I want CCU40.OUT1 tell me wheather this timer is running or not.
Wait your reply on line.
best regards,
Lucas
Hi Lucas,
I don't think you could see any output since it is in capture mode.
So I think you should check on the GCST.CC4yST bit to know whether the timer is running or not.
rgds,
Rou
