06:52 AM
Feb 14, 2017
06:52 AM
I am using XMC4500 Relax Kit.
I have connected VREF to VDD3.3.
I have also connected P14.0 and P14.8 to VDD3.3.
Yet after reading result register I am unable to read 4095 value (expected - Full Scale Reading). I get a different value every time.
void adcInit(void)
/* Initialization data of VADC Global resources */
XMC_VADC_GLOBAL_CONFIG_t g_global_config =
.clock_config =
.analog_clock_divider = 3,
.msb_conversion_clock = 0,
.arbiter_clock_divider = 1
//---------------------- Voltage Measurement ------------------------------------------//
/* Initialization data of a VADC group */
XMC_VADC_GROUP_CONFIG_t g_voltage_group_config =
.class1 =
.conversion_mode_standard = XMC_VADC_CONVMODE_12BIT,
.sample_time_std_conv = 3U,
XMC_VADC_QUEUE_CONFIG_t g_voltage_queue_config;
/* Channel configuration data */
XMC_VADC_CHANNEL_CONFIG_t g_voltage_channel_config =
.input_class = XMC_VADC_CHANNEL_CONV_GROUP_CLASS1,
.result_reg_number = RES_REG_NUMBER,
.alias_channel = XMC_VADC_CHANNEL_ALIAS_DISABLED
/* Result configuration data */
XMC_VADC_RESULT_CONFIG_t g_voltage_result_config =
.event_gen_enable = true,
.data_reduction_control = 3,
.wait_for_read_mode = true,
.post_processing_mode = XMC_VADC_DMM_REDUCTION_MODE
/* Queue Entry */
XMC_VADC_QUEUE_ENTRY_t g_voltage_queue_entry =
.channel_num = CHANNEL_NUMBER,
.refill_needed = true, /* Refill is needed */
.generate_interrupt = true, /* Interrupt generation is needed */
.external_trigger = true /* External trigger is required */
/* Initialize the VADC global registers */
XMC_VADC_GLOBAL_Init(VADC, &g_global_config);
/* Configure a conversion kernel */
XMC_VADC_GROUP_Init(VADC_GROUP0_PTR, &g_voltage_group_config);
XMC_VADC_GROUP_QueueInit(VADC_GROUP0_PTR, &g_voltage_queue_config);
/* Configure a channel belonging to the aforesaid conversion kernel */
XMC_VADC_GROUP_ChannelInit(VADC_GROUP0_PTR,CHANNEL_NUMBER, &g_voltage_channel_config);
/* Configure a result resource belonging to the aforesaid conversion kernel */
XMC_VADC_GROUP_ResultInit(VADC_GROUP0_PTR, RES_REG_NUMBER, &g_voltage_result_config);
/* Add the channel to the queue */
XMC_VADC_GROUP_QueueInsertChannel(VADC_GROUP0_PTR, g_voltage_queue_entry);
/* Connect Request Source Event to the NVIC nodes */
//XMC_VADC_GROUP_QueueSetReqSrcEventInterruptNode(VADC_GROUP0_PTR, XMC_VADC_SR_GROUP_SR0);
XMC_VADC_GROUP_SetResultInterruptNode(VADC_GROUP0_PTR, RES_REG_NUMBER, XMC_VADC_SR_GROUP_SR0);
//XMC_VADC_GROUP_ChannelSetEventInterruptNode(VADC_GROUP0_PTR, CHANNEL_NUMBER, XMC_VADC_SR_GROUP_SR0);
/* Enable IRQ */
NVIC_SetPriority(VADC0_G0_0_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(), 63, 0));
NVIC_EnableIRQ(VADC0_G0_0_IRQn);
/* Enable the analog converters */
XMC_VADC_GROUP_SetPowerMode(VADC_GROUP0_PTR, XMC_VADC_GROUP_POWERMODE_NORMAL);
//--------------------------------- High Side Current ------------------------------------------//
XMC_VADC_GROUP_CONFIG_t g_current_high_group_config =
.class1 =
XMC_VADC_QUEUE_CONFIG_t g_current_high_queue_config;
XMC_VADC_CHANNEL_CONFIG_t g_current_high_channel_config =
XMC_VADC_RESULT_CONFIG_t g_current_high_result_config =
/* Queue Entry */
XMC_VADC_QUEUE_ENTRY_t g_current_high_queue_entry =
//* Initialize the VADC global registers */
XMC_VADC_GROUP_Init(VADC_GROUP1_PTR, &g_current_high_group_config);
XMC_VADC_GROUP_QueueInit(VADC_GROUP1_PTR, &g_current_high_queue_config);
XMC_VADC_GROUP_ChannelInit(VADC_GROUP1_PTR,CHANNEL_NUMBER, &g_current_high_channel_config);
XMC_VADC_GROUP_ResultInit(VADC_GROUP1_PTR, RES_REG_NUMBER, &g_current_high_result_config);
XMC_VADC_GROUP_QueueInsertChannel(VADC_GROUP1_PTR, g_current_high_queue_entry);
XMC_VADC_GROUP_QueueSetReqSrcEventInterruptNode(VADC_GROUP1_PTR, XMC_VADC_SR_GROUP_SR0);
/* Enable IRQ */
NVIC_SetPriority(VADC0_G1_0_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(), 63, 0));
NVIC_EnableIRQ(VADC0_G1_0_IRQn);
XMC_VADC_GROUP_SetPowerMode(VADC_GROUP1_PTR, XMC_VADC_GROUP_POWERMODE_NORMAL);
//---------------------- Low Side Current ------------------------------------------//
XMC_VADC_GROUP_CONFIG_t g_current_low_group_config =
.class1 =
XMC_VADC_QUEUE_CONFIG_t g_current_low_queue_config;
XMC_VADC_CHANNEL_CONFIG_t g_current_low_channel_config =
XMC_VADC_RESULT_CONFIG_t g_current_low_result_config =
/* Queue Entry */
XMC_VADC_QUEUE_ENTRY_t g_current_low_queue_entry =
XMC_VADC_GROUP_Init(VADC_GROUP2_PTR, &g_current_low_group_config);
XMC_VADC_GROUP_QueueInit(VADC_GROUP2_PTR, &g_current_low_queue_config);
XMC_VADC_GROUP_ChannelInit(VADC_GROUP2_PTR, CHANNEL_NUMBER, &g_current_low_channel_config);
XMC_VADC_GROUP_ResultInit(VADC_GROUP2_PTR, RES_REG_NUMBER, &g_current_low_result_config);
XMC_VADC_GROUP_QueueInsertChannel(VADC_GROUP2_PTR, g_current_low_queue_entry);
XMC_VADC_GROUP_QueueSetReqSrcEventInterruptNode(VADC_GROUP2_PTR, XMC_VADC_SR_GROUP_SR0);
/* Enable IRQ */
NVIC_SetPriority(VADC0_G2_0_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(), 63, 0));
NVIC_EnableIRQ(VADC0_G2_0_IRQn);
XMC_VADC_GROUP_SetPowerMode(VADC_GROUP2_PTR, XMC_VADC_GROUP_POWERMODE_NORMAL);
//---------------------- Common Routine ------------------------------------------//
voltageComplete = false;
currentCompleteLow = false;
/* Perform calibration of the converter */
XMC_VADC_GLOBAL_StartupCalibration(VADC);
//XMC_VADC_GROUP_QueueTriggerConversion(VADC_GROUP0_PTR);
//XMC_VADC_GROUP_QueueTriggerConversion(VADC_GROUP1_PTR);
//XMC_VADC_GROUP_QueueTriggerConversion(VADC_GROUP2_PTR);
void VADC0_G0_0_IRQHandler(void)
/* Read the result register */
voltageAdc = XMC_VADC_GROUP_GetResult(VADC_GROUP0_PTR, RES_REG_NUMBER);
voltageComplete = true;
/* Acknowledge the interrupt */
XMC_VADC_GROUP_QueueClearReqSrcEvent(VADC_GROUP0_PTR);
