Hi all,
I am using my XMC1400 board with VDD set to 3.3 V. For certain measurements I need a range from 0-5 V in a certain VADC channel. Is it possible to set the input range from 0 to 5V without changing VDD to 5V?
Thank you
User12775
Whether you use 3.3V or 5V for the VDD, the Vref is always 5V. But you need to set the VDD range.
2528.attach
Thank you
However, is it possible to use Vref = 5V as a reference to the VADC module with VDD set to 3 V?
User12775
You didn't understand my reply.
The Vref is always 5V if you use the internal reference, but you need to set the SHSCFG register according to your VDD suply.
