XMC™ Forum Discussions
User7795
Level 4
Level 4
Hi Infineon,
at app ETH_LWIP of XMC4500, I need support for phy KSZ8081MNX (uses MII-Mode). As far as I see, I only have to create the file xmc_eth_phy_user_defined.c. Is this correct please?
A second question:
at app ETH_LWIP, when I select as PHY KSZ8081RNB, why is it possible to select as interface MII? This chip has no MII interface, only RMII.
Best Regards
Wolfgang
jferreira
First like received 750 replies posted 500 replies posted
Yes this is correct you need to place a file in your project which implements the interface described in xmc_eth_phy.h.
Regarding the second question, at the moment there is no logic in the APP constraining the MDIO interface depending on the selected PHY.
User7795
Level 4
Level 4
Hi Jesus,
thanks for your answer. I stored the user defined file to dir Dave/Generated/ETH_LWIP, where the other phy files are located.
Dave compiles without error, but each "Generate Code" deletes the file. Dave should backup the file before "Generate Code" and then restore it.
Best Regards
Wolfgang
jferreira
You should not modify manually the contents of DAVE folder, as you already experienced it is regenerated every time user click in the Code Generation button.
User7795
Level 4
Level 4
Hi Jesus,
But where should the user defined file (selectied in the app mask) containing the specs for the phy be stored? Dave expects this file at the same location where the Dave generated phy files are stored, that is at:
Dave/Generated/ETH_LWIP/
Or am I wrong?
Best Regards
Wolfgang
