jferreira
5 sign-ins First like received 750 replies posted
If you are using FreeRTOS, with Percepio Tracealyzer you get a superb solution for performance analysis, debugging and validation of RTOS-based embedded software.
Go and read Using-Tracealyzer-with-Infineon-XMC4500.pdf
User15898
Hi Jesus,
Currently trying to get Tracealyzer running on one of our projects. Using the XMC4500 but having some trouble getting the steaming mode running, the snapshot functionality is working but when trying to stream the code breaks in startup_XMC.s as soon you start the session.
3883.attach
Is your example still available? The link in the PDF says my access is forbidden.
Kind Regards,
Ryan
