Jan 14, 2014
09:15 AM
Jan 14, 2014
09:15 AM
I'm using UART with DMA. (XMC4500 AA)
I want to implement the RTS pin by software.
Is there way to generate an interrupt after transmitting the last bit of the UART?
12:06 AM
Jan 15, 2014
12:06 AM
Hi edgardocerone,
You can enable the interrupt for Transmit Shift Event.
This event occurs when the last bit of the data word is transmitted out from the microcontroller.
