03:28 PM
Jan 11, 2017
03:28 PM
Hello Forum.
I thought I had an understanding of the USIC (in UART mode).
I have a 20 byte buffer that I need to send packets out on to a listening peripheral.
However, I'm only seeing16 bytes. Well that's all the other side is receiving.
I am using an XMC4500.
My code is setup:
Help?
My code is setup:
#define UART_RX P3_12
#define UART_TX P3_11
XMC_GPIO_CONFIG_t uart_tx =
.mode = XMC_GPIO_MODE_OUTPUT_PUSH_PULL_ALT1,
.output_level = XMC_GPIO_OUTPUT_LEVEL_HIGH,
.output_strength = XMC_GPIO_OUTPUT_STRENGTH_STRONG_SOFT_EDGE
XMC_GPIO_CONFIG_t uart_rx =
.mode = XMC_GPIO_MODE_INPUT_TRISTATE,
XMC_UART_CH_CONFIG_t uart_config =
.baudrate = 115200U,
.data_bits = 8U,
.frame_length = 8U,
.stop_bits = 1U,
.oversampling = 16U,
.parity_mode = XMC_USIC_CH_PARITY_MODE_NONE
/* code to setup uart */
XMC_UART_CH_Init(XMC_UART2_CH1, &uart_config);
XMC_UART_CH_SetInputSource(XMC_UART2_CH1, XMC_UART_CH_INPUT_RXD, USIC2_C1_DX0_P3_12);
/* Setup FIFO's */
XMC_USIC_CH_TXFIFO_Configure(XMC_UART2_CH1,32U,XMC_USIC_CH_FIFO_SIZE_32WORDS,1U);
XMC_USIC_CH_RXFIFO_Configure(XMC_UART2_CH1,0U, XMC_USIC_CH_FIFO_SIZE_32WORDS,0U);
XMC_UART_CH_Start(XMC_UART2_CH1);
XMC_GPIO_Init(UART_TX,&uart_tx);
XMC_GPIO_Init(UART_RX,&uart_rx);
/*Set service request for UART protocol events*/
XMC_USIC_CH_SetInterruptNodePointer(XMC_UART2_CH1, XMC_USIC_CH_INTERRUPT_NODE_POINTER_PROTOCOL,0U);
/*Set service request for tx FIFO transmit interrupt*/
XMC_USIC_CH_TXFIFO_SetInterruptNodePointer(XMC_UART2_CH1, XMC_USIC_CH_TXFIFO_INTERRUPT_NODE_POINTER_STANDARD, 3U);
/*Set service request for rx FIFO receive interrupt*/
XMC_USIC_CH_RXFIFO_SetInterruptNodePointer(XMC_UART2_CH1, XMC_USIC_CH_RXFIFO_INTERRUPT_NODE_POINTER_STANDARD, 0x5U);
XMC_USIC_CH_RXFIFO_SetInterruptNodePointer(XMC_UART2_CH1, XMC_USIC_CH_RXFIFO_INTERRUPT_NODE_POINTER_ALTERNATE, 0x5U);
/*Set priority and enable NVIC node for transmit interrupt*/
NVIC_SetPriority(USIC2_3_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(), 63U, 0U));
NVIC_EnableIRQ(USIC2_3_IRQn);
/*Set priority and enable NVIC node for receive interrupt*/
NVIC_SetPriority(USIC2_5_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(), 63U, 0U));
NVIC_EnableIRQ(USIC2_5_IRQn);
/* Ready to receive */
XMC_USIC_CH_RXFIFO_EnableEvent(XMC_UART2_CH1, (uint32_t)((uint32_t)XMC_USIC_CH_RXFIFO_EVENT_CONF_STANDARD | (uint32_t)XMC_USIC_CH_RXFIFO_EVENT_CONF_ALTERNATE));
Help?
06:24 PM
Jan 12, 2017
06:24 PM
More on this... I must be doing something wrong with the trigger because in my transmit ISR -- if I delay before every byte into the FIFO the other gets it.
Here is a snip of the code:
if I take out the my_delay the other side get screwed up data. It's like the baud rate is being ignored...
I'm not sure what I'm missing.
/*Transmit ISR for the UART*/
void USIC2_3_IRQHandler()
if (g_runtime_ptr->tx_data_index < g_runtime_ptr->tx_data_count)
/*When Transmit FIFO is enabled*/
/*Fill the transmit FIFO */
while (XMC_USIC_CH_TXFIFO_IsFull(XMC_UART2_CH1) == false)
/*Load the FIFO byte by byte till either FIFO is full or all data is loaded*/
XMC_UART_CH_Transmit(XMC_UART2_CH1,g_runtime_ptr->tx_data[g_runtime_ptr->tx_data_index]);
my_delay(20000);
(g_runtime_ptr->tx_data_index)++;
else
break;
Jan 13, 2017
01:07 PM
Jan 13, 2017
01:07 PM
Hi -stv,
can you please send your main file like you sent me for the PWM issue? It will save me some time if I start with something that is already working if there is a delay.
Deni
Deni
09:30 AM
Jan 17, 2017
09:30 AM
08:57 AM
Jan 30, 2017
08:57 AM
Deni,
Have you had a chance to look at this? I think there is another thread that is having a very similar problem.
-stv
-stv
