12:24 PM
Jan 20, 2016
12:24 PM
I have been trying to use xmc_1400 UART example in DAVE 4 but I see garbage using my Tera term any ideas? and my serial port setting is correct, normally that is when you see garbage
Jan 21, 2016
01:19 AM
Jan 21, 2016
01:19 AM
Can I confirm that by port settings, this includes the baud rate of 57.6kbits/s being configured correctly?
Are you able to see the sequence of 14 bytes in hex values or they are completely random values?
If possible, can you test with another hyperterminal such as docklight evaluation version or mttty?
Min Wei
Min Wei
05:10 AM
Jan 21, 2016
05:10 AM
Hi Min Wei,
I am using this with XMC_1300 development board not 1400 but in the configuration I don't see any difference between 1300 and 1400 in this example, I used mttty and it is the same (garbage)
when you compile it and it goes to debug display the debug play key is off already, normally it should be on and then you run it
thanks in Advance,
thanks in Advance,
11:55 AM
Jan 21, 2016
11:55 AM
YES IT INCLUDES 57600 BAUD RATE
const uint8_t message[] = "Hello world!!\n";
void SysTick_Handler(void)
uint32_t index;
static uint32_t ticks = 0;
ticks++;
if (ticks == TICKS_WAIT)
XMC_GPIO_ToggleOutput(LED);
for (index = 0; index < sizeof(message) - 1; index++)
XMC_UART_CH_Transmit(XMC_UART0_CH1, message[index]);
ticks = 0;
uint32_t index;
ticks++;
ticks = 0;
12:06 PM
Jan 21, 2016
12:06 PM
the original uart is working but it doesn't work in my project, sorry for confusion I think this my learning curve, I was programming a 1400 in 1300 without changing processor, that would do it.
12:19 PM
Jan 21, 2016
12:19 PM
got it,
I needed to eliminate the first one
XMC_SCU_CLOCK_Init(&clock_config); eliminated this and it starts working
SysTick_Config(SystemCoreClock/TICKS_PER_SECOND);
