Sep 22, 2014
04:40 AM
Sep 22, 2014
04:40 AM
Hi everybody,
is it possible to have two Ethernet ports with one XMC4500?
More specifically:
1) Using the Evaluation Kit, can I connect two COM satellite ports to a single XMC CPU Board?
2) I see that DAVE only allows a single ETH001 app, so is there any chance I can have two Ethernet ports and still develop with DAVE, or do I need my own OS?
The background for my question is that I want to communicate with two different networks from a single XMC4500 CPU board.
Thank you!
More specifically:
Thank you!
04:59 AM
Sep 22, 2014
04:59 AM
AFAIK the xmc4500 only has one ethernet core. You need to hook up an external lan chip like the cs8900,r8139 or something better. It has nothing todo with an os!
thk
thk
Sep 22, 2014
10:50 PM
Sep 22, 2014
10:50 PM
No, Strictly not possible.
No, there is only one Ethernet MAC within the XMC4500 which can be connect to an external PHY.
01:01 AM
Sep 23, 2014
01:01 AM
Hi Christian,
you have only one MAC port. I don't know if using a switch can fit your needs (take a look for example at Micrel's line card).
