The data contained in the Flash space 0x10000F34
Fergus_wang
Distributor - Weikeng(GC)
First comment on blog First reply posted 10 sign-ins
 The microchip part is XMC1302-T038X0200 with AB setp. I want to know details of data contains in flash address of 0x1000,0F34 which explains Temperature-sensor constant data 2 in XMC1300-AB UM.  Pls tell me the functions of those data and how to use this data.
Vasanth
Hi Fergus,
Kindly check the following appnote : https://www.infineon.com/dgdl/Infineon-ApplicationNote_How_To_Use_On-Chip_Temperature_Sensor_XMC1000...
This explains how to use internal TSE block to for temperature calculation. The values you have referred as used for this measurement.
Vasanth
Vasanth
Hi Fergus,
Vasanth
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
Have you solved the problem, now?
