User16557
Dear Team,
just got the Speed 2Go Kit, installed software, but cannot start it, please see the screenshots.
Could you please help?
I have checked github for this software, maybe I was not using the right keywords, could I build it myself?
Thank you
Oleh
3460.attach
3461.attach
grambich
First question asked 5 replies posted First comment on blog
3 weeks ago first problems rised with the Version 1.1.
We fixed the problem and tested on several plattforms.
The updated version 1.2.0 will be available soon on our webpage.
BR, Klaus Grambichler
User16557
Hello and thank you for the fast reply! looking forward to it.
Best
Oleh
jferreira
5 sign-ins First like received 750 replies posted
User16557
Hi Jesusm
Thanks! It works 🙂 Is there the source for the sensor available? A sample for ARM Cortex would be great.
Thank you and best regards
Oleh
Karthik_Bala
Hi Oleh,
What is the application for this sensor?
Meantime, I will check if there is source code available.
Karthik
User16557
Hi Karthik,
The use-case is to detect the speed of a toothed gear. I have a dev kit from infineon and tried the windows software, it shows good results, now I would like to try it on a custom board with arm cortex m0 mcu. Was hoping to get more samples and manuals on this sensor.
Thank you and best,
Oleh
Karthik_Bala
Hi Oleh,
Thanks for the reply. We are still checking internally for source code
Karthik
