08:34 PM
Mar 29, 2017
08:34 PM
Mar 30, 2017
02:51 AM
Mar 30, 2017
02:51 AM
Read the datasheet and describe your problem in detail.
https://www.infineon.com/dgdl/SP37_1300kPa_PB.pdf?fileId=db3a3043382e83730138566f83105c7c
Aug 04, 2017
12:03 AM
Aug 04, 2017
12:03 AM
Hi Zongru.
Which compiler must be used for the SP37 sensor?
where can i found registers description document of the SP37 sensor?
thanks.
thanks.
Aug 04, 2017
08:19 AM
Aug 04, 2017
08:19 AM
It is a 8051 based chip.
You could use any 8051-compiler.
Aug 04, 2017
08:20 AM
Aug 04, 2017
08:20 AM
As for the datasheet, I figure you must ask your infineon sales or support for it.
Try contact sensors@infineon.com.
I have the datasheet but I could not share it to you. Because it is not permitted by Infineon.
Aug 04, 2017
12:49 PM
Aug 04, 2017
12:49 PM
Thank you Zongru.
your help was great.
I use Keil compiler C51 now.
have you paid the cost for the SP37 datasheet?or enough i buy SP37 sensor from infineon?and they give to me datasheet?
thank you.
thank you.
Aug 05, 2017
09:38 AM
Aug 05, 2017
09:38 AM
You don't need pay for the datasheet.
You even don't need to buy any chip to get the datasheet.
But you should contact the sales man and tell them your plan.(What product do you want to design? The volume, the development plan, etc.) Then you sign NDA with them and they will give you the datasheet and relevant information.
Aug 06, 2017
05:39 AM
Aug 06, 2017
05:39 AM
Thank you.
Feb 13, 2020
03:29 AM
Feb 13, 2020
03:29 AM
It is a Pressure sensor with a range from 100 up to 450kPa
