XMC™ Forum Discussions
working on SD card example below
http://www.keil.com/appnotes/files/apnt_273.pdf
with different IO pins for SPI Interface of Micro SD card with XMC4700
unable to write data on micro SD Card.
the I/o are:
P6_4 -- MOSI
P6_3 -- MISO
P6_4 -- CLK
P6_4 -- Chip Select.
Naveen Reddy
Senior Firmware Engineer
Navsemi Energy
Bangalore
User18035
Hi, we've the same problem. Do you have found a solution to your problem?
Thanks, kind regards.
Luca
