My SPI Master is configured in Sending a 16 bit Data from (0 to 16), the Data is perfectly in the TBUF and, the Read operation is Done by the Register RBUF in the slave mode, my word length is 7 and framlength is 7 , The Problem is the received data (DSR) of the RBUF is always showing 8, I am not able to view the Rest of the data is it because of my word length and framlength?
Thank you,
Ravi
Hi Ravi,
Your Master is sending 16 bit data in one frame?
If yes, then you should configure your slave data frame to 16 bit as well.
